| Print Page | Close Window |
2008 mazda tributePrinted From: the12volt.comForum Name: Car Security and Convenience Forum Discription: Car Alarms, Keyless Entries, Remote Starters, Immobilizer Bypasses, Sensors, Door Locks, Window Modules, Heated Mirrors, Heated Seats, etc. URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99821 Printed Date: May 15, 2026 at 3:07 PM Topic: 2008 mazda tribute Posted By: slicksam Subject: 2008 mazda tribute Date Posted: December 09, 2007 at 7:33 PM Looking wiring info on the 2008 mazda tribute? any different from the 2007? ------------- Testing is the key Replies: Posted By: moonliter Date Posted: December 09, 2007 at 8:03 PM Check the download section for 2008 ford escape, should be very close.
Posted By: Twelvoltz Date Posted: December 09, 2007 at 8:28 PM Audiovox Lists:
#513378: 2008 MAZDA TRIBUTE 4DR SUV Audio/Mobile Video WIRE COLOR POLARITY LOCATION Battery WHITE/ RED (+) RADIO HARNESS Ground BLACK/ GRAY (-) RADIO HARNESS LF Speaker (+) WHITE LF Speaker (-) WHITE/ BROWN RF Speaker (+) WHITE/ VIOLET RF Speaker (-) WHITE/ ORANGE LR Speaker (+) WHITE/ GREEN LR Speaker (-) BROWN / YELLOW RR Speaker (+) BROWN / WHITE RR Speaker (-) BROWN / BLUE Steering Cntrls OPTIONAL Radio Security YES Security WIRE COLOR POLARITY LOCATION Battery BLUE/RED (+) IGNITION SWITCH HARNESS Ignition 1 WHITE/ ORANGE (+) IGNITION SWITCH HARNESS Starter 1 BLUE/WHITE (+) IGNITION SWITCH HARNESS All Door Trigger GRAY/VIOLET (-) IN HARNESS IN DRIVER KICKPANEL THE INDIVIDUAL DOOR PINS REST AT (-) AND GO TO AN OPEN CIRCUIT WHEN THE DOOR IS OPENED Domelight Super BROWN (-) AT VEHICLE LIGHT SWITCH LF Latch GREEN/ VIOLET (OPEN) AT SMART JUNCTION BOX IN DRIVER KICKPANEL RF Latch WHITE (OPEN) AT SMART JUNCTION BOX IN DRIVER KICKPANEL LR Latch GREEN (OPEN) AT SMART JUNCTION BOX IN DRIVER KICKPANEL RR Latch YELLOW (OPEN) AT SMART JUNCTION BOX IN DRIVER KICKPANEL Trunk Trigger GRAY/ORANGE (OPEN) AT SMART JUNCTION BOX IN DRIVER KICKPANEL Parking Lights VIOLET/WHITE (+) IN HARNESS IN DRIVERS KICKPANEL Convenience WIRE COLOR POLARITY LOCATION Headlights-Lo YELLOW/BLUE (+) AT VEHICLE HEADLIGHT SWITCH Headlights-Hi GRAY/BROWN (-) AT VEHICLE HIGH BEAM SWITCH LF Pk Lt Bulb VIOLET/WHITE (+) AT FRONT LEFT PARKING LIGHT RF Pk Lt Bulb VIOLET/WHITE (+) AT FRONT RIGHT PARKING LIGHT LR Pk Lt Bulb VIOLET/WHITE (+) AT REAR LEFT PARKING LIGHT RR Pk Lt Bulb VIOLET/WHITE (+) AT REAR RIGHT PARKING LIGHT All Hazrd Lights BROWN / YELLOW (-) AT VEHICLE HAZARD SWITCH LF Hazrd Bulb BLUE/GREEN (+) AT FRONT LEFT TURN LAMP RF Hazrd Bulb YELLOW/VIOLET (+) AT FRONT RIGHT TURN LAMP LR Hazrd Bulb GRAY/BROWN (+) AT REAR LEFT TURN LAMP RR Hazrd Bulb VIOLET/ORANGE (+) AT REAR RIGHT TURN LAMP Parking Brake GRAY/BLUE (-) AT SMART JUNCTION BOX IN DRIVER KICKPANEL Trnk Release BROWN / BLUE (+) AT SMART JUNCTION BOX IN DRIVER KICKPANEL THIS WIRE IS THE GLASS RELEASE Remote Start WIRE COLOR POLARITY LOCATION Battery BLUE/RED (+) IGNITION SWITCH HARNESS Ignition 1 WHITE/ ORANGE (+) IGNITION SWITCH HARNESS Accessory 1 VIOLET/GREEN (+) IGNITION SWITCH HARNESS Starter 1 BLUE/WHITE (+) IGNITION SWITCH HARNESS Anti-Theft Type FORD PATS® OR SECURILOCK® VEHICLE IMMOBILIZER Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER Key Sense BLUE/GRAY (+) IGNITION SWITCH HARNESS Tachometer TAN (AC) AT INJECTOR #1 Speed Sense VIOLET/ORANGE (AC) AT PCM MODULE UNDER HOOD ON FIREWALL Parking Lights VIOLET/WHITE (+) IN HARNESS IN DRIVERS KICKPANEL Brake Lights VIOLET/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL Horn BROWN (-) IN HRNESS AT STEERING COLUMN ALSO AT SMART JUNCTION BOX IN DRIVER KICKPANEL Anti Theft RX VIOLET/GRAY Anti Theft TX YELLOW/RED Modules WIRE LOCATION Please select another category Doorlocks/Windows WIRE COLOR POLARITY LOCATION Power Unlock YELLOW/VIOLET (-) IN HARNESS IN DRIVER KICKPANEL MUST USE A RESISTOR FOR INTEGRATION PowerLock BLUE/GREEN (-) IN HARNESS IN DRIVER KICKPANEL Driver Mtr Unlock GRAY/BROWN (REV) DRIVER DOOR LOCK MOTOR Driver Mtr Lock BLUE/GREEN (REV) DRIVER DOOR LOCK MOTOR Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation. ------------- Installer, IT support, and FFL. I need less hobbies. |
