alarm remote start on a 1998 cavalier
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99927
Printed Date: May 13, 2026 at 6:33 PM
Topic: alarm remote start on a 1998 cavalier
Posted By: mcneil2608
Subject: alarm remote start on a 1998 cavalier
Date Posted: December 12, 2007 at 10:27 AM
Hi ,
i don't know if any one can help me out. i have started installing a remote start on a 1998 chevy cavalier. where would i find the wires for the door locks and and door triggers ?. and what type of circuit is it..positive or negative?...i have a carvox security system. can i just tap into the wires directly ?..or do i need relays?
SidBoy
Posted By: KarTuneMan
Date Posted: December 12, 2007 at 10:32 AM
LOCK Lt.blue In either kick panel   Rev Pol
 Locks are mastered from the passenger side.
 UNLOCK White In either kick panel   Rev Pol
 DOORPIN SEE NOTES
 LT.GREEN/ BLACK cover the driver's door and LT.BLUE covers all other doors. These wires are found at the BCM above the driver's kickpanel on the violet connector.
Date Posted: December 12, 2007 at 11:21 AM
thanks a lot Gary.
i have one more question . i configured my bypass. then i dissconnected the battery to hook up the wires to the remote start. will i have to reprogram the bypass or will it keep the codes
SidBoy
Posted By: wwizard
Date Posted: December 12, 2007 at 6:36 PM
my pasy experience with produ cts I use is that they keep there memory
Date Posted: December 13, 2007 at 9:21 AM
Thanks a lot wwizard..i just wanted to make sure that when i finally hook up all my wires i have a sense of where i can start troubleshooting if it does not work....you all have been very helpful.. i will let you know how it turns out. hopefully i can get it done this weekend if the weather cooperates...this forum is a good thing.
SidBoy
