Wiring diagram
Forum Name: Miscellaneous - Off Topic
Forum Discription: Topics that just don't fit anywhere else.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13450
Printed Date: March 26, 2026 at 8:08 AM
Topic: Wiring diagram
Posted By: mk166@wmconnect
Subject: Wiring diagram
Date Posted: May 12, 2003 at 1:37 PM
I need  the windshield wiper system wiring diagram for a Chevy S-10 , 1995 model.
Maurice
Posted By: hotrodelectric
Date Posted: May 13, 2003 at 8:07 PM
This is from the Chevy Astro book I have (stuff like this tends to be simular throughout sections of GM's range):
from the wiper fuse (25A): white- this goes to the wiper switch and the wiper motor.
from the wiper switch: gray- this goes to the wiper motor
and controls the low speed function.
from the wiper switch: purple- this goes to the wiper motor and controls the high speed function.
from the wiper motor: pink- this goes to the washer motor.
there may also be a brown wire from the switch to the motor- the switch function for the washer.
When testing the motor for function- do NOT connect a direct battery ground to the motor case- you will burn the circuit board that controls the motor.
Date Posted: May 14, 2003 at 11:43 AM
Thanks for the info., I have found my problem.
Maurice
