bypassing chevy voltage regulator
Forum Name: Miscellaneous - Off Topic
Forum Discription: Topics that just don't fit anywhere else.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15814
Printed Date: March 24, 2026 at 8:24 PM
Topic: bypassing chevy voltage regulator
Posted By: slowride59
Subject: bypassing chevy voltage regulator
Date Posted: July 03, 2003 at 7:51 AM
Hi Group, I saw someone where you can install certain wires on a GM regulator to be able to use an alt. with an internal regulator. Does anybody know the link for such info.? Thanks
sloooowride59
Date Posted: July 03, 2003 at 7:52 AM
sorry I meant somewhere
sloooowride59
Posted By: hotrodelectric
Date Posted: July 04, 2003 at 12:21 AM
https://www.roadsters.com/parts/
https://www.hotrodders.com
https://www.hotrodsusa.com
https://www.parts.com
https://www.streetandperformance.com
OK Slowride- there's a few links for you to check out. Most of these are links to multiple sellers- there's just too many who sell one-wire alternators to list individually. I personally don't like one-wire alternators- the regulators on most of them tend to be problem prone, but they are easy to rebuild if a problem crops up, and an 'emergency' conversion to standard 3-wire is simple if it ever becomes necessary. Street & Performance has a very good one, but it does cost more.
You can also check out a Kragen or a Checker if you have one near you- they do stock them, they can get them in various colors as well as polished, and the warranty is a selling point.
