1990 toyota carolla trunk switch
Forum Name: Miscellaneous - Off Topic
Forum Discription: Topics that just don't fit anywhere else.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22657
Printed Date: May 16, 2026 at 1:09 PM
Topic: 1990 toyota carolla trunk switch
Posted By: theatreguy69200
Subject: 1990 toyota carolla trunk switch
Date Posted: December 10, 2003 at 1:25 PM
ok short and sweet.I have a 1990 toyota carolla dx 4 door sedan. Bought it used and trunk key doesnt work.Been using the switch in front driver`s side and this morning the switch stopped working. How would I get the trunk open without having to pull the back seat out and pull out my speakerboxesand amps? Please help me. thanx ------------- just asking.
Posted By: Teken
Date Posted: December 10, 2003 at 4:07 PM
1. Why does the key not work? Is the cylinder broken?
2. I would ask you to check the fuse for the trunk release first, replace if needed.
3. Varify that the switch is fine, by doing a resistive measurment, with regards to a open, or hi resistive contact within the housing.
4. If none of the above work, locate the relay for the unit and test it, if it is fine, move on to the soleniod in the trunk.
5. You should check that the wiring is unchanged and is fine, with respect to power distribution to the trunk release module.
Regards
EVIL Teken . . .
Date Posted: December 12, 2003 at 11:08 AM
dont know why the trunk key wont work. We bought the car used and rebuilt .It was obviously hit from the back passenger`s side and to the best of my knowledge was the only time it was in an accident. Ihave onwed it for a few months and the other day when I opened the trunk it worked fine. but when I closed it and then tried to open itup to get something out (5 mins later) the lil pull switch gave no resistance as in it would not catch. The trunk wont open and thinking I may need to get a CHILTON MANUAL in the future. ------------- just asking.
Posted By: auex
Date Posted: December 12, 2003 at 1:22 PM
Nooo, don't get the Chilton's. They suck IMO.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Teken
Date Posted: December 12, 2003 at 6:16 PM
Theatreguy,
You could do a simple check. Simply remove the momentary push botton switch, and connect both wires together, for a second or so.
If the trunk opens, you have found your problem, and replace the switch. If the trunk still does not open, then you will have to locate the fuse for the unit, and replace as required.
If the fuse is fine, then the next step is to ensure there is no binding / tension in the trunk lid. Which may be preventing the soleniod from actuating.
Listen to the trunk as you touch both wires from the switch to hear if the soleniod is even attempting to engage.
Again, if the trunk opens and closes with no resistance, then you should follow through and locate the relay for the soleniod.
Test it, and varify its operation and its resistive values in the coil.
Worst case simply stick in a new relay to see if it changes the situation.
If not, move on to the soleniod. If you simply take the power wire and and engage the soleniod you should here it attempting to pull in the pull cord of the soleniod dowell pin.
If it does not engage, you have found your problem, and replace the soleniod.
Follow the above and you will eliminate 90% of the possible area's that may be affecting your trunk release.
You will of course varify the most basic. Which is that there is a proper ground and power going to the unit. This could be as simple as a broken ground wire, to a open power cable.
Check the basics, as for the manual. If you intend to keep this vehicle for a long time. And wish to reduce the amount of maintenance costs associated to the vehicle and wish to do some of the duties which your personl mech would do.
Invest in a Helms manual. If it helps you to resolve *only one* automotive problem, which saves you the time and money to pay someone else to figure out.
Than, it has paid for itself 10 fold.
You may purchase one on-line at wwww.helminc.com
Regards
EVIL Teken . . .
Posted By: Teken
Date Posted: December 12, 2003 at 6:22 PM
You know I just re-read your last reply. Is this trunk release a cable style?
Annd not one which is powered and released using a soleniod?
LOL, if it is, please forgive my lack of attention.
If, it is a pull cord style. The simplest thing to do is to ensure that the actual pull cord is in fact still attatched to the handle.
If not, you will of course have to repair the cable, and the ring terminal which holds it in place.
Regards
EVIL Teken . . .
Posted By: rowboat
Date Posted: December 17, 2003 at 11:29 AM
from what you say i believe the trunk was replaced and the lock was not switched. a locksmoth may be able to pick the lock open then check for a code to have a key made,he also should be able to impression the lock making you a key. it is possible the cable has broken or come disconnected.in any case you need to get the trunk open to repair.
------------- keep smiling tomorrow will be better
Posted By: KaMLuNg
Date Posted: December 19, 2003 at 10:28 PM
heh the keyhole doesn't work in my corolla either.. it looks like the lock is rusted from the inside.. i have to keep popping it from the insdie...
