noise problems
Forum Name: Miscellaneous - Off Topic
Forum Discription: Topics that just don't fit anywhere else.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27852
Printed Date: March 21, 2026 at 12:11 AM
Topic: noise problems
Posted By: dad2am
Subject: noise problems
Date Posted: March 06, 2004 at 9:38 PM
i have a pioneer head unit , two 12" performance teknique subs and two amps. my problem is altinator wine. when i play a cd the noise is gone, its when i turn on the radio the noise appears. and i noticed the radio gives off a loud thump when i change radio stations. their is no thump when i turn the car or radio on or off. it seems to be the radio signal more then anything. i tried new rca's and nothing. any help or good sites would be great. thanks in advanced.
stevie
Posted By: dad2am
Date Posted: March 06, 2004 at 10:13 PM
the radio also gives a loud thump when the volume goes 0 to 1 when i play cds and radio. when the rcas are disconected the popping and wine is gone. but i tried new rcas and the problem still persists to wine
stevie
Posted By: Ravendarat
Date Posted: March 07, 2004 at 6:32 PM
I would guess that its a problem with the antenna in he car. Try disconnecting the antenna and just stick like an allen key or a small screw driver or somthing metal in the small hole in the center of the anntena plug on the deck. Now with the deck out of the dash try to tune in your radio. If the noise is gone then you know its a problem with the antenna in the car, if not then it could be a bad ground on the deck.
Posted By: dad2am
Date Posted: March 08, 2004 at 9:34 PM
thanks for the info bro. i tried what you said and found it wasnt the antena. turn out i have a bad set of rca inputes in the back of my deck. i trie a new set of rca's and plugged them in the front inputs and everything works great. thanks again bro.
stevie
