Wipers switching on when turn signal is used?
Forum Name: Miscellaneous - Off Topic
Forum Discription: Topics that just don't fit anywhere else.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=3642
Printed Date: May 04, 2026 at 11:46 AM
Topic: Wipers switching on when turn signal is used?
Posted By: nickm81
Subject: Wipers switching on when turn signal is used?
Date Posted: September 14, 2002 at 11:43 PM
My car is a 1989 Chevy Cavalier in good condition. However, every once in a while, when I use the turn signal, my wipers flash on for a single wipe, then immediately stop again. I'm not hitting the wiper knob at all when I signal, and sometimes the wipers flash on for no apparent reason when I'm just driving along.
Is there an electric short somewhere that I don't know about, or is it something else? Any help is MUCH appreciated. Thanks.
               Nick
Posted By: chriswallace187
Date Posted: September 15, 2002 at 7:17 PM
Does your Cavalier have a single multi-function lever for turn sigs., wipers, dimmer, and cruise? Or does it have two levers: one for wipers, and the other for turn signals and headlights and cruise? If it's got the single lever, that might just be bad, so you could try replacing it.  If two levers, they might be connected on the column somehow.
C Renner's Auto Electronix
Posted By: Harry
Date Posted: September 15, 2002 at 7:20 PM
I have an 88 Cavalier that does the same thing, I had it to a couple shops. They couldn't find anything wrong, so I just live with it..............Harry
Posted By: TKelly
Date Posted: October 10, 2002 at 2:04 PM
You may want to check the Technical Service Bulletins (TSB's) for your car to see if there is a recall/model wide problem.  There are several web sites where you can do this.  Some Chevrolet Blazers in the late 80's had this problem which was repaired free by the dealer by replacing the multi-switch on the steering column.  (My '89 Blazer had the same problem and was repaired by the dealer as part of a recall) Some of the later Mazda/ranger pick-ups have had similar problems which were part of a recall.
TLK
