larger horn for Cavalier
Forum Name: Miscellaneous - Off Topic
Forum Discription: Topics that just don't fit anywhere else.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=459
Printed Date: May 24, 2026 at 5:12 AM
Topic: larger horn for Cavalier
Posted By: rog2
Subject: larger horn for Cavalier
Date Posted: April 25, 2002 at 8:45 PM
I have a '92 Cavalier. The horn is anemic, it really is almost worthless, lol.
I would like to simply go to the junkyard and get a horn from a Buick or a Cadillac...etc...and install it in my Cavalier...
But I wonder if  any of the components of the electrical system in the Cavalier would be fried by ( I assume) the larger electrical requirements of a more powerful horn?
Anyone in here know if  simply hooking up another (larger) horn to my Cavalier would cause any type of problems?
Thanks in advance......
Posted By: pat28ca
Date Posted: April 26, 2002 at 8:48 AM
go right ahead. if any thing the horn might sound better
Posted By: rog2
Date Posted: April 28, 2002 at 11:00 PM
thanks for taking the time to reply pat28
of course i am hopin'  the horn will sound better, lol,  as it is it can barely be heard ..and on the interstate next to an 18 wheeler it's as if it isn't even audible
i know i can "go right ahead"  and it would work...for a while...
but what i fear is that OTHER parts of the (fragile) Cavalier electrical system might not be heavy duty enough for a higher output horn from a more substantial model of GM car
that's why i am seeking advice from someone more knowledgable than myself
What about the horn relay?  would that burn out? there used to be a thing called the voltage regulator ( i may be dating myself here, lol) might that  get fried?
..anyway...I just dont want to slap in a $10  junk yard horn from a Cadillac and later find out that i have fried some $400 part available only from the Chevy dealer....
Anybody else have an opinion????
Posted By: mobiletoys2002
Date Posted: April 29, 2002 at 12:28 AM
Well if you want to be on the safe side you can always go to radio shack get yourself a spdt relay and some heavier guage wire and use that to power the horn.To do this you will need to find the positive wire that reads 12 volts when the horn is preessed that will go to pin 86 of the relay then pin 85 will be ground.pin 87 will be positve 12 volts fused at the battery with a 5 amp or ten see which one works well and pin 30 will be the positive output to the new horn. I meen at least this way will cost you an extra 5 dollars and a little work but you will know that it will not burn anything. good luck.
Posted By: pat28ca
Date Posted: April 29, 2002 at 8:08 AM
hook it up the way that mobile says. just remember that there are different types of relays  the spdt means" single pole double throw" .  see current is like having water and you are trying to fill a bucket. small bucket means that you will reach it's limits quickly. large bucket , you can fill it till the cows come home. so if you got a better horn, then chances are that you'll be ok
Posted By: pat28ca
Date Posted: April 29, 2002 at 8:11 AM
all car horns work on the same amount of voltage 12 volts so you really shouldn't have to hook up a relay. the problem will come when you hold the horn for long periods of time. just honk like every other normal person and eveything should be fine
