Home electrical problem
Forum Name: Miscellaneous - Off Topic
Forum Discription: Topics that just don't fit anywhere else.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=59615
Printed Date: April 14, 2026 at 9:05 PM
Topic: Home electrical problem
Posted By: andy84
Subject: Home electrical problem
Date Posted: July 18, 2005 at 1:06 AM
I have a question about home wiring (110 AC).
I have a nightlight in the living room that has a light sensor in it (comes on at night, off in the day). Tonight it was flickering, but I noticed whenever I touched any part of the nightlight, it would be on and stop flickering. The entire outside of the nightlight is plastic. I replaced the bulb and it did the same thing. I also noticed that if i hold my finger on the plastic outer-casing, i can feel a mild shock going through me.
Then, I noticed in my kitchen that when I turned on the 2 fluorescent lights, they only light up on the ends and won't come on until i reach up and touch them, then they light up and stay on.
It seems like the electrical devices are grounding through me...does that make sense?
This is an older house that I am renting, and I doubt that the wiring is as good as it should be.
Also, I got a very mild shock from an electrical fence yesterday, although that probably doesn't have anything to do with it.
If you have any idea whats going on, let me know. Thanks!
Posted By: stevdart
Date Posted: July 19, 2005 at 8:15 PM
You are beginning to go through THE CHANGE. Uncle Fester was like that, too.
Posted By: speedwayaudio1
Date Posted: July 21, 2005 at 3:35 PM
get your landlord to get a electrition in there.
------------- Big Dave
Posted By: adrianspeeder
Date Posted: July 24, 2005 at 3:16 PM
Just change the fluorescent bulbs as they seem to be wearing out. Unless they are the older kind that take a little screw in starter that would need to be changed.
Is this night light the cheapo plug in ones at walmart in a two pack for a buck? Just change it.
Adrianspeeder
------------- '02 F250 PSD, '97 F-150, '71 F-100, '66 F-250, '93, '92, '88, '84 Broncos
Penn State electrical engineerin' major
