3000w inverter
Forum Name: Miscellaneous - Off Topic
Forum Discription: Topics that just don't fit anywhere else.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66681
Printed Date: May 15, 2026 at 7:50 AM
Topic: 3000w inverter
Posted By: vinster888
Subject: 3000w inverter
Date Posted: November 20, 2005 at 6:28 PM
i installed said inverter into my van. i used #0 wire to run my batteries in parallel on the positive side. i used #0 from inverter to trans, 2nd battery to trans, and 1st battery to motor for negative side. works awesome with 1000w loads but when i get over that the gen light comes on and the voltmeter goes in the tanker. would a larger alternator fix my issue? i normally wouldnt go over 1500w or so.
i am an electrician and i like to use the inverter for service changes. power off to the house, i can still run drills or the customers fridge.mostly i use it for charging 18v batteries.
Posted By: chriswallace187
Date Posted: November 21, 2005 at 1:14 AM
It wouldn't hurt to get a higher amp alternator...that or a remote start that activates when it senses the voltage getting low.
------------- C Renner's Auto Electronix
Posted By: CutDog504
Date Posted: November 24, 2005 at 2:06 PM
Wht kind of 18v batteries are you charging? If its for a dewalt drill I know DeWalt makes a charger that plugs into your 12v cigarette lighter.
Date Posted: November 24, 2005 at 9:41 PM
Ryobi. im wondering if i need an isolator or someting to make sure the second battery gets a good charge? is there something about the second batttery in the system not getting as good a charge as the first battery?
