contact dermitis issue anyone else too?
Forum Name: Miscellaneous - Off Topic
Forum Discription: Topics that just don't fit anywhere else.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89708
Printed Date: April 30, 2026 at 5:08 PM
Topic: contact dermitis issue anyone else too?
Posted By: BoominRolla
Subject: contact dermitis issue anyone else too?
Date Posted: January 28, 2007 at 4:20 PM
I realize that probably none of you in here are doctors but I thought you might be able to lead me in the right direction.
I went to the doctors awhile ago and show him my right hand. He calls it contact dermitis (contact with skin) It only affects my right hand and its only on the upper 2" or so of my middle finder, pointer finger, and thumb...  He first said exima. But the weird thing is that its like the skin is cracking in a few spots and its sometimes raw and sore. Sometime it just "peels" for no reason like the outside layer has seperated. Kinda like a blister would? But only in very small spots. Now I use jergens ultra healing hand lotion once and awhile but it dosen't seem to help much with the really affected areas. The only thing I can think of that it could possibly be is twisting the wires for crimping during an installation... Like for a butt connector. Does anyone else on here go through this if so what do you use? Any affective "Thin" gloves that can still allow for accurate grabbing of small wires and holding of tools and or screws for reinstallation of pannels?
Posted By: Velocity Motors
Date Posted: January 29, 2007 at 10:27 AM
I solder all my connections and the way that I do the wire connection it requires very little twisting of the wires. For very dry skin that is cracking and has open sores you may want to try vitamin E cream. I used to work at a pharmacy for 5 years and over the years we had alot of women that worked in hair dressing and they would have to wash up to 10 clients every day and this was hard on their hands. So we looked into this and vitamin E cream was the best that these women had used. It's very expensive for a small amount but it does work.
You may want to look into a different techinique on your wire connections or use solder instead of the crimps.
