windows roll when arming
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103647
Printed Date: May 01, 2026 at 1:51 PM
Topic: windows roll when arming
Posted By: richardcaraball
Subject: windows roll when arming
Date Posted: April 02, 2008 at 3:12 PM
what do i need  for windows rollup
whats the setup
my car bmw 328i has a factry rollup. put  key in the door and lock and hold and the windows rollup and sunroof close
the alram I am using is a viper 791xv
Posted By: ya boy mike
Date Posted: April 02, 2008 at 10:19 PM
Directed makesa window module, 530T, which will do two windows in both directions, as well as roll up when armed. The 529T is what is recommended for a sunroof I believe.
Should be able to pick each up from a local Directed dealer.
Mike
It Hz
Date Posted: April 03, 2008 at 12:14 AM
can i use the factory  rollup system
Posted By: jonnyafk
Date Posted: April 11, 2008 at 11:12 AM
if the alarm has a programmable timed output, you can use that on a relay to control the lock coming from the key cylinder. if you want it operate when you lock the vehicle, you would have to use a PAC TR-7 to work as a timer.
