wiring actuated license plate
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104799
Printed Date: May 03, 2026 at 6:48 AM
Topic: wiring actuated license plate
Posted By: hallperson
Subject: wiring actuated license plate
Date Posted: May 17, 2008 at 3:23 PM
hey guys,
i made a topic about a year back trying to wire my actuated license plate up. but know a year later finally gettin to put it in. i was tryin to find out how to wire it so that when the truck comes on it will go down and when the truck is turned off it will go up. but the motor does not have limiting switches to stop it. you have to hold the switch down until it shows completely. then the same to hide it away. but i want it all to be stand alone so i dont have to touch it. the motor has only 2 wires coming off of it and the switch just reverses polarity.
any help would be great   thanks
Posted By: hotwaterwizard
Date Posted: May 17, 2008 at 7:05 PM
posted_image
Al you need now is a way to cut power when up and down.
posted_image
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
Date Posted: May 18, 2008 at 8:44 AM
is it possible to make a time controlled circuit like it would run for 5 seconds or so     thanks alot joe
Date Posted: May 18, 2008 at 7:55 PM
posted_image
You can change the timing by changing the capacitor.
47uF = 3 sec
100uF = 10 sec
220uF = 15 sec
470uF = 30 sec
1000uF = 1min
posted_image
Stockton California
