relay, power antenna
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104801
Printed Date: May 03, 2026 at 8:13 AM
Topic: relay, power antenna
Posted By: larryreyes66
Subject: relay, power antenna
Date Posted: May 17, 2008 at 4:03 PM
I have an old car that has a 2 wire antanna switch when pushed one way it gives 12 volt and the other wire is not ground or positive and visa versa when pushed the other way. I purchased a new power antenna and it has 2 wires, one needs to be ground and one needs to be poistive for it to go up and the visa versa for it to go down. I want to make this work with the original switch I need to make the this work how can i do it with 2 relays? Cant seem to figure it out! Thanks
Posted By: hotwaterwizard
Date Posted: May 17, 2008 at 6:47 PM
Do you have a picture of the switch Front and Back?
I think you can make it work if we can figure out how the original switch works.
What Make and year car is it out of?
Maybe we can find a wiring Diagram for the original switch then modify the wires to do what you want.
If you use a DPDT center off Toggle switch you can do the same thing.
posted_image
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
Posted By: i am an idiot
Date Posted: May 17, 2008 at 7:56 PM
posted_image
Date Posted: May 17, 2008 at 8:15 PM
posted_image
posted_image
Stockton California
