Relay to Detect/Switch Engine Running?
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105642
Printed Date: April 05, 2026 at 3:26 AM
Topic: Relay to Detect/Switch Engine Running?
Posted By: ifitstuff
Subject: Relay to Detect/Switch Engine Running?
Date Posted: June 23, 2008 at 5:31 PM
Hi,
there are devices out there to detect engine running giving out ignition feeds on vehicle with few ignition feeds available, such as most modern CAN Bus cars. Useful for fitting towbars and head units.But i think they`re expensive for what they do.
Has anyone made one?
I`ve attempted this using a small low draw Relay and a variable resistor. But guess what.. Didn`t work.
any ideas???
Posted By: KPierson
Date Posted: June 23, 2008 at 5:46 PM
A frequency switch can be connected to a fuel injector to let you know when the motor is running.
Kevin Pierson
Date Posted: June 23, 2008 at 5:53 PM
Sorry, i wasn`t looking to detect the engine running exactly. I was looking for a cheap relay circuit that would give out a 12v when the engine runs. For use with fitting aftermarket Head units, Towbars etc on CAN Bus cars.
Posted By: i am an idiot
Date Posted: June 23, 2008 at 8:26 PM
I can tell you how to do this on newer GM and Chrysler products.  I think that there is a pink wire on the GM units, the problem is that if you connect anything with even the least bit of current draw, it freaks the computer out.  Simply connect the transistor as it is in the picture.
https://www.radioshack.com/product/index.jsp?productid=2062611&cp=&sr=1&origkw=npn&kw=npn&parentPage=search
posted_image
I know that this is a 15 amp transistor.  Without a heat sink it will easily supply 2 amps of output.  If you need more than 2 amps, you MUST use this device to trigger a relay.  You MUST insulate the metal tab, it has 12 volts on it.  I build these things for every shop in town.  The original need for the device was as stated on the pic, was to provide a switched out for an XM or Sirius tuner.
Date Posted: June 24, 2008 at 8:47 AM
Thanks very much for that, but that`s not what i meant either.. I`m gonna have to think of a way to `re-phrase` my question.. lol posted_image
