1 pulse to latch 3 second
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106419
Printed Date: May 05, 2026 at 11:35 PM
Topic: 1 pulse to latch 3 second
Posted By: megatfauzi76
Subject: 1 pulse to latch 3 second
Date Posted: July 29, 2008 at 1:03 AM
Hai,
Can anyone guide me. How to make 1 pulsed generate 3 second latch? Detail how to wired to relay and whay kind of capacitor i need.
Thank You
Posted By: davngr
Date Posted: July 29, 2008 at 2:13 AM
ddirected 528t  has an adjustable timer   and  directed 452t  is an actual pulse generator don't know how long the pulses are.
life is a comedy to think, a tragedy to feel
Date Posted: July 29, 2008 at 9:11 AM
Thanks for the reply..
528t is expensive way...Im searching for cheapest way...Can anyone help me?
Posted By: dualsport
Date Posted: July 29, 2008 at 8:04 PM
This is cheap-
posted_image
Date Posted: July 30, 2008 at 10:33 AM
Thanks dualsport..
Look complicated...Can u advise me..how to do only use relay,capacitor,diode and resistor?
Date Posted: July 30, 2008 at 10:50 AM
Sorry Dual Sport...
Forgot something...can u modified this diagram to be 1 puls to 3 second latch? I found it in one of the forum...it been design from you..
posted_image
Thanks again
Date Posted: July 31, 2008 at 9:55 PM
The other circuit is supposed to take two pulses and only pass the second pulse through, it doesn't really change the timing like you want.
If you just want a three second pulse output when you send in a short pulse, the first one would be the one to try.
If you're planning to send in a positive going pulse, then you wouldn't need the inverter chip. Just put the pulse into the diode directly.
Posted By: hotwaterwizard
Date Posted: August 09, 2008 at 6:09 PM
posted_image
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
