about to rewire classic car, mosfets?
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114478
Printed Date: May 14, 2026 at 8:17 AM
Topic: about to rewire classic car, mosfets?
Posted By: drummerian
Subject: about to rewire classic car, mosfets?
Date Posted: June 15, 2009 at 3:47 PM
Hey people,
I am about to rewiere the switch panel in my classic mini and was wondering if anyone had experimented with using MOSFETs instead of relays.
The swithces will be:
rear heated screen, hazzard lights, lights and starter button
The obvious advantages are:
Smaller form factor
No switch noise
Theoretically unlimited lifespan
So whats the disadvantages?
Ian
Posted By: lspker
Date Posted: June 15, 2009 at 9:06 PM
Disadvantages
Smaller form factor
switch debouncing
limited current
heat build up
cost
Posted By: dualsport
Date Posted: June 15, 2009 at 11:34 PM
The main concern is that using them takes more careful consideration of the MOSFET's specifications for the application, designing for protection against transients when connected to inductive loads, and general fear of electronic things.
Relays are pretty much immune to mishandling, while MOSFETs require more care to safeguard against damage from electrostatic discharge. Lots of people just prefer simple stuff like relays over mysterious electronic stuff that have no moving parts.
Relays are easier to work with when dealing with bidirectional signals since they don't care which way the current is flowing as much as transistors do. Double throw is easier to do with relays also.
With proper heatsinking, MOSFETs that can handle a lot of current are available. If the circuit is put together with it just hanging in the air, it'll overheat.
