relay coil with diode, terminal polarity?
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114805
Printed Date: May 06, 2026 at 3:35 PM
Topic: relay coil with diode, terminal polarity?
Posted By: sundancer268
Subject: relay coil with diode, terminal polarity?
Date Posted: July 02, 2009 at 5:59 AM
I have a relay that has the diode built in across the coil.
I need to know if the 85 or 86 terminal should be the positive terminal and which should be the negative.
Thank you.
Posted By: i am an idiot
Date Posted: July 02, 2009 at 6:15 AM
85 is ground.
Date Posted: July 02, 2009 at 4:58 PM
Thank you.
