on board relay
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116383
Printed Date: May 06, 2026 at 2:06 PM
Topic: on board relay
Posted By: dudeman87
Subject: on board relay
Date Posted: September 17, 2009 at 6:02 PM
I  installed a car alarm and the  on- board relay  which  is used for the parking light flash  went out !!  Does anyone know where i can buy  a replacement relay  or could i just install a regular relay and will that work?
Posted By: Ween
Date Posted: September 17, 2009 at 7:16 PM
make and model of the car alarm please.  and yes of course it may be possible.
m
Date Posted: September 17, 2009 at 7:24 PM
It's a autopage rf-320
Posted By: i am an idiot
Date Posted: September 17, 2009 at 8:10 PM
I have seen only a handfull of bad relays in alarms. There was visible damage on each of them.  Is there visible damage on yours?  If not, what makes you think it is bad?
But to answer your question, yes they can be replaced.  And yes you can figure out which terminal of the onboard relay is the trigger wire and run that wire out to a Standard SPDT automotive relay.
Date Posted: September 19, 2009 at 9:48 PM
It was working for a while   then  the alarm brain would make a  clicking sound   and  cause the alarm to chirp non stop  until  I removed  the fuse  on the  parking light  input wire.
Date Posted: September 19, 2009 at 10:31 PM
The parking lights pull more current than anything else on the alarm system.  If the parking light feed was attached to the same point that the alarm's constant wire was connected, you may have a bad connection, that is good enough to power the rest of the system but when the lights were trying to flash, the connection showed that it was bad.
Date Posted: September 20, 2009 at 7:42 AM
Thanks I  will try that.
Date Posted: September 20, 2009 at 3:34 PM
Dam you are good!!!  That was the problem  thanks !!
