relay
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118081
Printed Date: April 19, 2026 at 8:42 AM
Topic: relay
Posted By: geo2slow4u
Subject: relay
Date Posted: November 28, 2009 at 8:15 PM
I need some help. I lost my diagram I used to have. What I am trying to do is. I have a momentery switch for my orverdrive button on my car. I wanna be able to turn my overdrive off then hit a switch and be able to use the button for my nitrous.
Posted By: i am an idiot
Date Posted: November 28, 2009 at 8:51 PM
Do you know if the other wire of the switch is connected to power or ground?  Do you know were the switched wire connects to the computer?
Date Posted: November 28, 2009 at 9:56 PM
I forgot about that. I am pretty sure its a hot. Not sure where the wire connects to the computer. But the last time I did it, I did all the connections in the column.
Date Posted: November 28, 2009 at 10:16 PM
If you know where the wires are in the column, that will be fine.   Give me a minute, I will draw you a picture.
posted_image
