fog lights on with hi/low, not w/ parking
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=119301
Printed Date: May 13, 2026 at 1:31 PM
Topic: fog lights on with hi/low, not w/ parking
Posted By: ace_boy2099
Subject: fog lights on with hi/low, not w/ parking
Date Posted: January 13, 2010 at 6:49 AM
Sorry if this is on here somewhere but out of all the threads I checked the closest thing I found was a closed topic for a mitsubishi that didn't have how they got the desired features just "Check the underhood fuse box". I have a 99 F-150 that didn't' come with foglights and I am planning on adding them and I saw on another site something about wiring a relay so that the fogs come on with the lowbeams and stay on with the high beams but not have anything to do with corner/turn lamps. What was said on the other site is I could wire the relay like this to get my desired feature. How does this sound to you, Would it work? 30 - Switched power 85 - low beams wire from headlight plug 86 - hi beams wire from headlight plug 87 - to Fog Lights + Would this send feedback to my dash and mess up my lights or would this work the way I am immagining it? also, would the fogs flash with the momentarily switch of hi to low and vice-versa ?
Posted By: Ween
Date Posted: January 13, 2010 at 1:10 PM
hi, you could also use the RED / yellow that connects the headlight switch to the high/low dimmer switch. connect that to term 86, ground term 85. m
Date Posted: January 13, 2010 at 2:15 PM
Ween]< wrote:
>hi,you could also use the RED / yellow that connects the headlight switch to the high/low dimmer switch. connect that to term 86, ground term 85. m
Oh, Cool, Thanks for the info. I will have to look into that.
Posted By: t&t tech
Date Posted: January 13, 2010 at 3:42 PM
You cannot have common polarity on both sides of a relay, the coil will not energize! using the same setup you described and assuming the polarity being switched is positive, wire just as you have it above, but ground 85 and diode hi/low beam outputs to terminal 86, band toward relay!
Posted By: howie ll
Date Posted: January 14, 2010 at 7:33 AM
There are two similar posts here showing the "double" relay required.
Rather than single pole changeover, it's a double pole and you will need another "normal" relay to power the feed.
Date Posted: January 14, 2010 at 10:17 AM
as long as it works, Wouldn't Ween's idea be the easiest and not need 2 relays? I plan on putting HIDs in the fog housings anyway so I only need the plug for a signal to trip the ballasts, from there the power comes directly from the battery.
Date Posted: February 14, 2010 at 8:42 AM
Hi, Update for all of you along with another question. I have the foglights in my truck and have it working like stock. I went to do a mod where the lights come on with the parking lights which intails jumping the parking light wire to the ground wire (BLACK/ white below) of the fogs but when i did that and I armed my alarm it flashed my HID Headlights, When I saw that I undid the mod and I'm now looking for how I can wire the vehicle so that I can have the foglights come on with the parking lights but not flash with the alarm. I have an extra relay laying around if i need it but I would like to try and keep it as clean as possable and only use 1 relay. If I do have to use 2 relays would this work or is this not set right???? If it isn't set right please tell me what I need to do to have it work the way I would like. [URL=https://img215.imageshack.us/i/eugenenonflashfogcustom.jpg/][IMG]https://img215.imageshack.us/img215/7117/eugenenonflashfogcustom.th.jpg[/IMG][/URL] If you have sugestions for changes please refer to them as "Change R1p30 from battery to radio fuse" so that I can figure it out. Thanks for any help you can provide.
Posted By: t&t tech
Date Posted: February 14, 2010 at 11:28 AM
I don't understand all of you post, you mentioned, the fog lights come on with the parking lights, but the headlights blink with the parking light on arming the alarm! Am i right? That's three different sets of lights! Not sure if i read you properly!
Date Posted: February 14, 2010 at 11:38 AM
I would like the fog lights to come on with the parking lights. There is a mod for my truck where you can jump the brown wire(parking +) and the BLACK/ white(all round -) wire at the headlight switch to get that result, but when I did that and armed my alarm it not only flashed the parking lights but the headlights too. When I saw that I undid the mod (took out the jumping wire) But I would like to have the fog lights that I am installing to be able to come on with the Parking lights, However, I don't wnat the fogs to flash with the parking once I get the HIS in them when I arm my alarm..
Posted By: t&t tech
Date Posted: February 15, 2010 at 4:12 PM
Oh! here's a way Using a single pole double throw relay wire like this Cut the parking light feed of the alarm and insert the three amp diodes bands away from alarm, connect one side to the original parking light connection in car (assuming here it's positive), and connect the other side to pin 86 on the relay Pin 85- Ground Cut either the positive or negative feed of both fog lights (doesn't matter) pin 30 - Connect one side of the severed lead here Pin 87a- connect the other side here! This way they won't turn on with the alarm, but will however else they are turned on! -------------
Posted By: oldspark
Date Posted: February 15, 2010 at 6:35 PM
Don't ya love fogs with low & hi.
At least here it is illegal to have fog on with other beams.
But I wonder what they call those lights under the bumpers that are on with beams (over here)?
Mind you, when rally driving, my fog lights were aka pencil (hi) beams else bi-Oscars (high-beam though maybe low).
