terminals 85 and 86
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=120810
Printed Date: May 12, 2026 at 10:41 PM
Topic: terminals 85 and 86
Posted By: larryc
Subject: terminals 85 and 86
Date Posted: March 19, 2010 at 8:45 AM
Is it ok to replace a relay that has terminals 85 and 86 (coil) reversed?
Hyundai 01 Elantra (part number Omron 95224-29000)
A dealership gave me a new relay with slightly different numbers and 85 and 86 are reversed.
Would this damage the electrical system to use it?
Posted By: howie ll
Date Posted: March 19, 2010 at 9:10 AM
No provided it doesn't have a built in diode.
Posted By: oldspark
Except for diodes, they are equivalent.
If spark-quenching/suppression diodes are fitted, the convention is that #86 is the +ve and #85 the -ve side of the relay's coil.
If reversed, the diode will short +12V to gnd until the diode blows, else the feeding circuit or fuse blows.
If it's a snubber/quenching resistor rather than a diode, then it won't matter - they are non-polar like the coil.
A relay should indicate a diode or resistor (rectangle) if they are included internally.
Posted By: larryc
Date Posted: March 19, 2010 at 11:36 AM
The relay is "rectangular" but not marked as to whether it has a diode.
Is there a way to test it for a diode?
thanks
Posted By: oldspark
Date Posted: March 19, 2010 at 4:28 PM
It's tricky - a voltage divider is probably best...
IE - if connected with a resistor of similar value (to the coil - probably between ~80 to ~200 Ohms) and place across 12V, in one direction the diode will short the coil hence reducing the coil's voltage to about 0.6 volts, or conversely, brightening the bulb if a test lamp is used - ie, a 3W bulb is about 60 Ohms.
But relays with diodes should be marked...
