relay, switch for rev acc lights.
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121532
Printed Date: May 11, 2026 at 2:41 PM
Topic: relay, switch for rev acc lights.
Posted By: projnostic
Subject: relay, switch for rev acc lights.
Date Posted: April 26, 2010 at 1:39 PM
Hello all. 2005 Dodge 2500
Hooked up 12v 30a relay for separate rev back up lights. Triggered off rev light. How can a switch of some sort be used to turn on lights when hooking up boat etc. without reverse lights on?
Diagram would be helpful.
Posted By: KPierson
Date Posted: April 26, 2010 at 2:28 PM
Install a switch AFTER the REV connection and diode isolate it from the reverse signal.
Kevin Pierson
Date Posted: April 26, 2010 at 2:41 PM
? bear with me as I am wire retarded. Rev goes into relay. so switch before relay? Four prong relay if it matters. And what is a diode? can i get it from auto parts place? Any kind of picture would help.
Thank you
Posted By: KPierson
Date Posted: April 26, 2010 at 3:56 PM
The relay should have a Pin 85 and Pin 86.  One of those should be connected to ground and the other should be connected to the "reverse" signal.  Whichever one is connected to the reverse signal cut that wire and install a 1n4001 diode from Radioshack with the band facing the relay.  Between the diode and the relay connect a switch that connects to 12vdc.
Sorry, don't have time to draw up a picture!
Kevin Pierson
Date Posted: April 26, 2010 at 4:26 PM
Thank you very much, I think I've got it. posted_image
I do appreciate ya. Headed to get parts now. Thanks again for your time. This will be neat and functional.
