2003 coupe g35
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121592
Printed Date: May 11, 2026 at 1:47 PM
Topic: 2003 coupe g35
Posted By: salvage12
Subject: 2003 coupe g35
Date Posted: April 29, 2010 at 12:57 PM
water salvage.. when i turned the key car wouldnt turnover.. auction a total loss to swap parts.. swaped all ecu components and now the car will turn over.. the total loss car would start with no problem and i just cant get the water damaged to fire.. what other solutions could i try to solve this?? im thinking this has to do with the fuel pump but i dont know how to check for that issue.. can anyone help me??
Victor12swap
Posted By: icearrow6
Date Posted: April 29, 2010 at 6:43 PM
Water damage? Exactly what was damaged?
if the car say was submerged in water. . . then there could be some serious damage to the engine that a new ECU would NOT fix.
Basically an engine will need FUEL, AIR, COMPRESSION and Electricity (spark) to start the engine.
Now, I assume a sort of mechanic had diagnose a "no spark" type of situation and you were advised to replace the ECU.
So make sure you have SPARK at the spark plugs, Fuel at the fuel injectors and at least 95Psi of compression at each of the pistons(V6 model).
On the same note, if by "water salvage" means possible engine water intake, then most likely some valves may have been bent if the car was running when the "water damaged" happened.
The engine is too complicated to simply point and swap parts blindly.
Date Posted: April 29, 2010 at 7:23 PM
thanks alot!! will start checking all that now..
Victor12swap
Posted By: KPierson
Date Posted: April 30, 2010 at 3:00 AM
Did you have the dealer program the replacement ECU to the car? You can't just drop in a replacement ECU and start it up - it has to be initialized to the car first.
Kevin Pierson
