pulse latching problem?
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=127848
Printed Date: May 14, 2026 at 2:10 PM
Topic: pulse latching problem?
Posted By: dave.towler
Subject: pulse latching problem?
Date Posted: July 07, 2011 at 1:21 PM
Hi, will do my best to explain the problem and hope someone one can advise....
posted_image
I used the above 5 relay setup to work as an ignition switch for remote start of a generator. When the generator starts it works fine on/off perfect. Once the generator has been running a while the relays fail to unlatch I guess this is a back feed? Can anyone explain how to alter to stop this happening? Thanks
Posted By: howie ll
Date Posted: July 07, 2011 at 3:51 PM
1N4004 across the coils, bands towards 86.
