relay triggering another relay
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=128256
Printed Date: May 15, 2026 at 1:31 AM
Topic: relay triggering another relay
Posted By: the12voltuser
Subject: relay triggering another relay
Date Posted: August 15, 2011 at 8:49 PM
Hi, i installed a set of aftermarket horns to replace my one wimpy horn but with the stock relay they still arent that loud. i tried putting a different relay in place of stock but still the same. i tried using the stock relay to trigger the relay horns came with and it was MUCH louder.    My question is , is it safe/ok to have the stock relay trigger a second relay triggering the horns? Thanks :)
Date Posted: August 15, 2011 at 8:50 PM
its on a 1996 nissan altima
Posted By: i am an idiot
Date Posted: August 15, 2011 at 9:53 PM
Using the OEM horn wire to trigger a relay will be fine.  It will actually be much less of a load on the horn circuit.
Posted By: howie ll
Date Posted: August 16, 2011 at 2:57 AM
Mount the trumpets inside the splash shield facing the road (down) installing them in the engine bay is a waste of time because the engine parts and installation muffle the sound. Also I'd use the original relay and if necessary upgrade the fuse, that's what I do and I've owned two Maximas and right now a smaller Nissan all with air horns.
If you piggy-back the second relay, (use the NEG horn push wire to trigger it), and you press the horn for a second or less,you get the original horns, hold the horn button longer for the air horns. Without the second relay it's instant.
Posted By: oldspark
Date Posted: August 16, 2011 at 4:05 AM
Keeping in mind the usual (traditional) "hot" relay with grounded horn-switch (ie, a 3-terminal relay, else "normal" with #30 & #86 connected together to +12V).
(I presume it's wired traditionally.)
I'd probably run a new fuse and heavier +12V power cable for the new horn(s), but that assumes it uses 4-terminal relay IF the horns only work with IGN (or ACC) on - ie, #86 of the new relay to "B" or +12V supply of the original relay, then #85 to the horn-switch (usually "S" on a 3-terminal horn relay) - unless you want the new horns to be usable at any time (then a 3-terminal horn relay or #86 to #30 as normal).
