500 ma ground increase
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134436
Printed Date: May 14, 2026 at 2:19 AM
Topic: 500 ma ground increase
Posted By: toolzoneplus
Subject: 500 ma ground increase
Date Posted: June 25, 2013 at 10:27 PM
I have hooked up engine kill for alarm and the orange wire for ground when armed is 500 mA which I have tested but it is not enough to ground out relay when armed, how do we increase this to activate relay when armed? I can take the relay wire and ground it to anything and it works but when I try to use the alarm wire that states grounded 500 mA when armed does not trigger relay
Posted By: i am an idiot
Date Posted: June 25, 2013 at 10:41 PM
Are you using a standard Bosch/Tyco relay? If so, there is a problem with your alarm brain. Those relays draw approx 160 MA. The following post may help even if the alarm brain is damaged.
https://www.the12volt.com/installbay/forum_posts.asp?tid=114792&KW=2n6491#556471
Posted By: KPierson
Date Posted: June 26, 2013 at 9:57 AM
Assuming this is for a standard street vehicle what you are trying to do won't work anyway. You can't use the (-) when armed wire to energize a relay as it will drain the battery in under 48 hours.
A standard Bosch relay should draw around 160mA so 500mA should be more then enough. Do you have any other devices connected to the orange wire? If so, they should all be diode isolated.
Generally with starter kill you hook up the (-) side to the (-) ground when armed and the (+) side to an ignition source that must be powered in order to start the car. This way, if someone is trying to hotwire the car the relay will energize.
------------- Kevin Pierson
Date Posted: June 26, 2013 at 2:59 PM
I only have the 12 volts hitting relay when you turn key on key side instead of continuose 12 volts. I will try the bosh relay tonight
Date Posted: June 26, 2013 at 3:02 PM
I am using a engine kill relay from ebay with the diode on it and I am sure it is not a bosh type relay I will try bosh type and see
Posted By: howie ll
Date Posted: June 26, 2013 at 5:05 PM
Make sure the band on the diode goes to 86 and your ground output to 85, in other words the GWA wire goes to the non banded side of the diode, the ignition wire to the banded side.
