Relay to neons
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13999
Printed Date: March 26, 2026 at 7:25 AM
Topic: Relay to neons
Posted By: Sebastian018
Subject: Relay to neons
Date Posted: May 26, 2003 at 10:15 AM
Hi, I have a set of Underbody Neon and They are connect it to a switch inside of the car, what i want to do is connect to a realy with the alarm so every time i press the Lock or Ullock bottom the light will turn on and then off... But I also want to be able to turn the neon lights With the switch inside of the car, How do I hook up the relay. I was thinking about doing it this way
85=Tapped into Siren Positive
86=Ground
30=Positive wire of neon (non COnstant)from the switch
87=Postive Fused 12+
But Idont know what is going to happen when I turn On the light With the switch, would the siren Turn on too, or not...
thank you
Posted By: philaf
Date Posted: May 27, 2003 at 6:53 PM
if you are worried about the signal feeding back to the alarm, simply throw a diode in line... diodes only allow signal to run in one direction.
now, a more important question... what is it that you want the lights to do? are you trying to make the lights blink like your parking lights do? if so, it won't work... the signal from your alarm is short (under one second)... the transformers for the neons take longer than that to warm up. the signal would have come and gone before the transformer ever warmed up enough for the lights to activate... you can try programming your alarm for a longer pulse (most go up to about 3.5 secs for cars with vacuum driven locks) but i don't know how your actuators will like getting a signal that long.. in either case you need to tap off the door trigger, not the siren output.
if you want to control the lights via remote.. one push one, next push off... check out the page about relays on the main site. they have a diagram that creates a latched on output from a momentary ground signal... i hooked my interior neons to this setup and now i can turn them on and off with the star button on my remote. since the key fob is at the ignition while driving, i have no need for a switch in the car.
hope i helped, and i hope it wasn't too confusing...
Posted By: BumpNGlow
Date Posted: May 29, 2003 at 11:39 AM
my buddy wrote up a diagram for his alarm.  you might be able to use the general concept of it at lesat for your alarm:
posted_image
or the pretty animated one:
https://www.cmeglow.com/Wiring%20Diagrams/wiringalarmdiagram2.gif
Date Posted: May 29, 2003 at 5:18 PM
thank you, I got the idea
