2000 ACURA Integra GSR sunroof relay
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=140
Printed Date: May 11, 2026 at 1:46 PM
Topic: 2000 ACURA Integra GSR sunroof relay
Posted By: shecret107
Subject: 2000 ACURA Integra GSR sunroof relay
Date Posted: March 25, 2002 at 7:43 PM
Hello,
     I have 2000 ACura Integra GSR, and Im attemting to use the (-) Aux Remote Output feature of my alarm (Crimestoppers CS2000) to open up the sunroof of my vehicle. Can someone help in wiring the relay for this feature. So far, this is what I have: Thanks in advance for the responses.
85 connected to gray wire from the CS2000 module
86 connected to ?
87 connected to ?
87a connected to?
30 connected to wire (+12v for sunroof to open)
Posted By: wirewise
Date Posted: March 25, 2002 at 8:29 PM
It would be best to use a window module to control your sunroof and you'd probably like the way it works much better than just using an output with a relay, but to control it with the relay you'd connect 85 to the gray wire, 86 and 87 to 12V+, 30 to the motor side of the open wire of the sunroof and 87a to the switch side of the open wire of the sunroof.
The output from your alarm needs to be a latching output meaning it supplies current for as long as you hold the button. If it's only a momentary output, you'll need to use a window module unless you want to hit the button about 30 times for it to open all the way :D.
~~wirewise~~
Date Posted: March 28, 2002 at 2:46 PM
Hey Wirewise,
     Thanks for the info...I finally hooked up everything, and the sunroof opens when the remote is depressed. I appreciate response...THANK YOU VERY MUCH!!!
