third ignition and secound accessory
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14206
Printed Date: May 21, 2026 at 7:37 PM
Topic: third ignition and secound accessory
Posted By: crash2ny
Subject: third ignition and secound accessory
Date Posted: May 30, 2003 at 3:19 PM
i have a 2001 saturn l200 ineed to know how to hook up the relays for the 3rd ignition and 2nd acc wires if any one can help
thank you
Posted By: crash2ny
Date Posted: May 30, 2003 at 6:48 PM
i forgot to tell the remote starter is a hornet 553t
Posted By: trusdamanr
Date Posted: May 31, 2003 at 3:53 PM
the third ignition is the key sense wire in the ignition harness.. it just needs to see a ground when remote started so take the blue/black wire on the six pin harness and connect to the lt.green keysense wire..ive never used a relay for the second acc, used the same acc wire output...but if you want to do it.....pin86--orange relay cable(little one)pin 85---red relay cable again smaller one,30 going to the second acc wire, and pin 87 to B+(12V)
