Mimicking the Ignition Wire
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145122
Printed Date: April 30, 2026 at 8:57 AM
Topic: Mimicking the Ignition Wire
Posted By: dougdv
Subject: Mimicking the Ignition Wire
Date Posted: December 30, 2018 at 8:32 PM
I have a DVR from a truck and it has red & black power cables and a thinner yellow cable which the manual says is to be hooked up to the ignition. I'm trying to get the device operating to play with it and have it hooked up to a 13.8v DC power supply. I presume I need a small current on the ignition wire to activate the power. What is the simplest way I can do this? Can this wire be connected to the positive of the power supply or does it need to run through a relay?
Posted By: geepherder
Date Posted: December 31, 2018 at 8:04 AM
You shouldn't need a relay for the ignition wire. You can connect directly, or install a simple toggle switch for ease of use.
