diodes relays and fun
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14673
Printed Date: May 21, 2026 at 10:48 AM
Topic: diodes relays and fun
Posted By: LittleBill
Subject: diodes relays and fun
Date Posted: June 09, 2003 at 5:17 PM
allright i have some questions about diodes, now say u have a item that pulls 24 amps when on, now say u put a diode inline on this power line, does the diode need to have a 24 amp rating? i would assume so, so my next question would be say u don't have 1 24 amp diode, could u wire 4 6 amp diodes in series to get the same effect or would u still fry the diode? and my last question i was told u could use a relay in conjunction so u would not need a high amp diode? could someone give me a real basic diagram on how this would work? thanks
Date Posted: June 09, 2003 at 5:44 PM
i have one more question too, where would i get the diodes? cus all i see are diodes from radio shack and none actually say blocking, can i use a barrel or rectifyer one?
Posted By: xetmes
Date Posted: June 09, 2003 at 6:07 PM
Yes if a diode is rated at 1 amp any more will make it glow :) . you could use a combination to allow for greater current draw. I like to buy electronics from digikey.com.
here are their diodes (tons to choose from): https://www.digikey.com/scripts/us/dksus.dll?Criteria?Ref=26810&Cat=30933663
Posted By: xetmes
Date Posted: June 09, 2003 at 6:11 PM
ohh a rectifier is a diode used to change AC to DC , you can use it the same, a bridge rectifier on the other hand is 4 diodes. If you see schottky it is a type of diode, that has a .4 V drop (if i remember correctly). If you look at the ones on that site, it is cheaper and much easier to just get a diode capable of handling the current.
Date Posted: June 09, 2003 at 6:43 PM
xetmes so my thought process is correct?, so that page u show me if i just punch in 30 amp 25v? what ever it spits out at me is fine??? like i said i don't know, all these diodes work, just do different things but all provide one way paths? so if i get a rectifier or a barrel? it will work ok for me? can i use these
https://www.radioshack.com/product.asp?catalog_name=CTLG&category_name=CTLG_010_005_003_016&product_id=276-1661, let me know, and if u have aim or something would u throw it to me i would like to talk to u one on one , if u don't mind
Posted By: xetmes
Date Posted: June 09, 2003 at 6:48 PM
They should work fine, if you look at the digikey pages most high current diodes are recitfiers and you must check if it can handle the current you need as the RMS current.
