lucas relay
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14934
Printed Date: May 21, 2026 at 8:05 AM
Topic: lucas relay
Posted By: vanorak
Subject: lucas relay
Date Posted: June 14, 2003 at 1:05 PM
old lucas 6RA relay for spot lamps...
the conneections are: W1,W2,C1 which is a two pin,and C2.
does anybody know which terminal is which,supply,and earth wise?
Cheers vanorak
Posted By: the12volt
Date Posted: June 14, 2003 at 2:35 PM
W1(+) and W2(-) refer to the coil of the relay. With your meter you should be able to determine the normally closed and open state of the other contacts.
posted_image the12volt • Support the12volt.com
Posted By: vanorak
Date Posted: June 14, 2003 at 7:36 PM
Thanks for the reply.posted_image
