Relay for LCD’s and DVD
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15876
Printed Date: May 16, 2026 at 8:52 AM
Topic: Relay for LCD’s and DVD
Posted By: Sebastian018
Subject: Relay for LCD’s and DVD
Date Posted: July 04, 2003 at 9:06 PM
HI, I need to know if What im going to do is right or not, I have two Tv's and One dvd player and the Playstation. The Tv's and the dvd are connected to the cigarrete plug, I want to make a clean installation that why I want to use a relay. I want to wire the relay this way:
First I want to add a Switch
Relay:
85: Ground
86: NonContant From the swich (12+ constant when the switch is on)
87: 12+ Fused
30: To THe TV's and the DVD (
Or
85: ground
30: 12+ Fused
87: Tv's and DVD
Is that RIGHT OR WRONG?
the tv have two wire + and two wire - which are supposted to be connect the Green(12V+) one to the Brake Switch for some law that you cant watch Tv while you are driving, Well I didnt connect it to the braKe I just connected to a 12+ Constant....
THANK YOU
Posted By: auex
Date Posted: July 05, 2003 at 12:11 PM
Either way works fine. It is similar to the diagram below, except the remote turn on lead would be the ign or acc wire and the additional accesories would be the monitors/dvd player. posted_image
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: July 05, 2003 at 12:17 PM
Ok.
