Relay location on a Toyota Camry 91
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16978
Printed Date: May 15, 2026 at 10:03 AM
Topic: Relay location on a Toyota Camry 91
Posted By: dade49
Subject: Relay location on a Toyota Camry 91
Date Posted: August 01, 2003 at 12:14 AM
I know I need 2 relays for my door lock system I added for my alarm. I was wondering if anyone knows where the relays are at on a 1991 Toyota Camry or where they usually are on most vehicles so I can get some from the junkyard? :) Any help would be appreciated. Thanx.
Posted By: auex
Date Posted: August 01, 2003 at 10:55 PM
Did you add aftermarket door locks to this, it sounds like you did? Why would you want the factory relays. Chances are that they will either not work or fail relatively soon.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
