remote radio turn on
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=1825
Printed Date: May 13, 2026 at 4:49 PM
Topic: remote radio turn on
Posted By: ShaunD912
Subject: remote radio turn on
Date Posted: July 10, 2002 at 12:42 AM
Hello, First of all, this site is great. It's helped me a lot. Anyway, I would like to know how to make the (-) aux channel on my alarm turn on and off my radio, preferably by pressing the same button, if possible. Any help would be appreciated.
Posted By: mobiletoys2002
Date Posted: July 10, 2002 at 1:05 AM
You will need a relay to switch that negative to a positive to turn your radio on. pin 85 will be that negativeaux input, pin 86,87 will both get 12 volts positive, and then pin 30 will go to your radios switched ignition lead. Now you may want to add a diode on the ignition lead of the radio that way no voltage goes on the car ignition wire while the radio is switched on with the remote. Now check in your alarms manual if you have and see what the options are for that aux output.And change to whatever you want the remote to do (latched with ignition or whatever that alarm offers) Any questions post back.
Date Posted: July 10, 2002 at 1:21 AM
I really appreciate it mobile. Perhaps you can help me with one more thing. I own a sidewinder 500esp. It doesn't mention anything about changing the remote to latched or anything like that. Any suggestions?
Date Posted: July 10, 2002 at 1:22 AM
Ill check let me get back to you  it should have it .
Date Posted: July 10, 2002 at 1:25 AM
are you sure you have a sidewinder not a viper?
Date Posted: July 10, 2002 at 1:27 AM
I thought it was a sidewinder but it may be a viper. Is there much difference between the two?
Date Posted: July 10, 2002 at 1:34 AM
no not really the wire colors are the same but viper is thier top of the line models and the programming is a little different . ok let me see what i got on this particualar alarm i will post back your answer.
Date Posted: July 10, 2002 at 1:37 AM
ok it does have this it is in menu 2 feature 9 you can do latched/latched , reset with ignition, 30 second timed, wich one do you want ill tell you how to do it?
Date Posted: July 10, 2002 at 1:38 AM
if latched will turn it on and off by pressing the same button, that's what i want to know
Date Posted: July 10, 2002 at 1:49 AM
You will open a door turn ignition on then back off,press and hold the valet switch untill you hear the alarm chirp 2 times then let it go press the valet 9 times then press and hold once more the alarm will chirp 9 times while holding the valet press the unlock button once on the remote that should do it if not e mail me and ill help you .
Date Posted: July 10, 2002 at 1:51 AM
ok thank you so much
Date Posted: July 10, 2002 at 1:53 AM
by the way this will control channel three of your remote how is yur remote set up now?
Posted By: GlassWolf
Date Posted: July 10, 2002 at 7:35 AM
if your aux button supports the option for latched output, you can use that for on/off of the radio, connecting the ignition lead through a relay to that trigger. push aux button, latched switch to on, triggrs relay, sends +12V to ignition/accessory wire of stereo, powers on radio. push again, kills accessory lead, radio turns off.
------------- -GlassWolf
Pioneer Stage-4, Orion, DynAudio, Fi
Posted By: omegamotorsprts
Date Posted: July 18, 2002 at 10:50 PM
i asked someone if you could setup a latch system off of one channel output of a remote, like if the system were on already the input would be interpreted as an off command and vice versa, they said it either couldn't be done or would be hard, i can't remember, is this true?
