momentary switch use
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21398
Printed Date: May 14, 2026 at 3:33 PM
Topic: momentary switch use
Posted By: dappa786
Subject: momentary switch use
Date Posted: November 12, 2003 at 7:14 PM
Hi. I am doing a neon install inside my car . I am hoping to connect up to 10 different types of neon and led based products inside my car. I was hoping to use  a momentary switch ( like a demister switch ) as I have a spare switch on my dashboard.
What relay would i need to use and how would i connect the switch to the relay as the switch is normally open. Also would 1 relay be sufficient to to power as many as 10 items.
Many thanks in advance.
dappa
Posted By: auex
Date Posted: November 12, 2003 at 8:24 PM
Using the diagram below you can use a momentary switch to turn on and off anything hooked to the relays.
posted_image
If you need more then thirty amps then just wire additional relays off of the +output of the relay on the right.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: dappa786
Date Posted: November 13, 2003 at 4:13 AM
thanks man. i will try it out and let you know.
dappa
