wiring acc pos. for head unit
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21549
Printed Date: May 14, 2026 at 8:26 AM
Topic: wiring acc pos. for head unit
Posted By: gtiguy
Subject: wiring acc pos. for head unit
Date Posted: November 16, 2003 at 2:34 PM
Does anyone know the correct way to wire an ignition switched +12 for cars that are'nt factory equiped, using spdt bosch relay??? I've read it somewhere I just can't relocate it. Any help would be cool!
Posted By: auex
Date Posted: November 16, 2003 at 9:01 PM
I wouldn't even use a relay for a deck turn on lead. Just run a wire from the acc wire at the ignition harness to the deck. I would however use a fuse.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: gtiguy
Date Posted: November 17, 2003 at 12:04 AM
Okay, thanks for knowledge. That is the route I have been running for quite some time now. Just curious if there was an ?alternative? and if headunit would benifit. Thanks again!
