Latching Relay, and momentary switch.
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21639
Printed Date: May 14, 2026 at 6:21 AM
Topic: Latching Relay, and momentary switch.
Posted By: tray262
Subject: Latching Relay, and momentary switch.
Date Posted: November 18, 2003 at 9:18 AM
Sorry for the stupid question, but this is what I have right now. I have a underbody neon kit with a 30amp relay with a small toggle switch, This is what I want to do, I've got a broken switch that fits into a stock location on my dash, so I gutted the switches from behind the buttons and mounted momentary switchs behind the buttons to use the stock housing. Now I need to figure out how to use the momentary switches. Any help would be great. And a note to the admins of this site, This site rocks aswsome info on here, can I add a link from my to here. Thanks, Tray.
Posted By: go2pac
Date Posted: November 18, 2003 at 10:39 AM
You can use my diagram here. Mines the one with the 4 relays.
Latching relay with momentary switch------------- Karl
Pacific Accessory Corporation
Mobile Audio Interfacing Equipment
Connecting You to Your Music Since 1976
Posted By: tray262
Date Posted: November 19, 2003 at 1:24 PM
Is this correct. If so I have a couple more questions. What size relays and what size diodes ? Sorry about the questions, but like I said I'm really super new to this also, I really have a passion to learn this. Thanks for the help. Tray.
Posted By: tray262
Date Posted: November 19, 2003 at 1:27 PM
Posted By: go2pac
Date Posted: November 20, 2003 at 1:39 AM
1 amp diodes are fine. You can use any SPDT relay as long as your circuit does not exceed the current rating of the relay.
------------- Karl
Posted By: tray262
Date Posted: November 20, 2003 at 8:01 AM
Karl, Thanks a lot for your help. Was everything else on little diagram fine ? If so, I'll try it out this evening, also what is the typical price for SPDT relay. Local Radio Shack didn't have any, so I went to best buy to price them from the install bay, they charge $12 each, I thought that was out of sight so I did bother. I'll got to AutoZone and see what they have. Tray
Posted By: Teken
Date Posted: November 20, 2003 at 8:26 PM
Either of the two links below will provide you with a more reasonable option for purchase.
www.partsexpress.com
www.allelectronics.com
I would also recommend that you do buy the relays that have a quenching diode in series of the coil. Also, buy the female 5 pin connectors for termination of the relay to your set-up.
This will allow you to have a trouble free installation without worries of loose crimps, or intermittent contacts to the relay terminals due to improper insertion of the connectors to the pin outs.
Regards
EVIL Teken .. .
