parking lights relay messing alarm
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28856
Printed Date: April 19, 2026 at 5:51 PM
Topic: parking lights relay messing alarm
Posted By: ravertony
Subject: parking lights relay messing alarm
Date Posted: March 22, 2004 at 5:45 PM
I have a Celica GTS 2002 and im having an annoying problem with my parking lights relay and alarm.  My alarm comes with a built in relay for the parking lights, but the output is a Positive 7A and on my vehicle the parking lights wire needs to be grounded in order for the lights to come on.  I used the reverse polarity relay setup on this website and the lights do flash when i arm the alarm, but after they flash the alarm makes error beeps (it does it when there's an electrical error or master reset).  Im guessing its causing a peak in power because of the high output from the internal relay in the alarm.  I dont know much about relays but can someone help, i looked around on the website but cant seem to find info on this.
Tony
Posted By: sparkie
Date Posted: March 23, 2004 at 8:15 PM
Hook the alarm's positive output to terminal #86 of the relay. Terminals #85 and #30 to a good ground. Terminal #87 to the negative trigger parking light wire in the car.
sparky
Date Posted: March 24, 2004 at 5:25 PM
Thanks for the info sparkie, but like I posted above I did convert the polarity with a relay already (what your giving me), but my problem is that it makes my alarm get errors.  Im guessing its causing a peak in power or some sort of reverse voltage and i started reading this other thread were they are talking about diodes with relay is that what i should do???
thanks again
tony
Posted By: its_radio_shop
Date Posted: March 24, 2004 at 9:02 PM
Yes try a diode on the relay. It will stop the reverse voltage spike.
