switching voltages 12V-->24V
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30304
Printed Date: April 19, 2026 at 5:30 PM
Topic: switching voltages 12V-->24V
Posted By: Big Blue
Subject: switching voltages 12V-->24V
Date Posted: April 13, 2004 at 12:14 PM
Hi,
I have a viper alarm/starter that I would like to put on my 24V Toyota Lancruiser. I have purchased a 20 amp 24v-->12v converter for the main power into the box.
My question is can I use a 12V relay with a 12V trigger to get a switched 24V output?
86 12V trigger
30 24V input
87 24V output
85 ground
I would assume it is just the coil that needs to see 12V and the contacts should be able to handle 24V??
I also need to switch the 24V glow plug light to 12V. Can I do this using a 24V relay and wire accordingly as above?
thanks
Brad
Posted By: xetmes
Date Posted: April 13, 2004 at 5:08 PM
yea it will work
Posted By: robbie2883
Date Posted: April 14, 2004 at 11:41 AM
it will work as long as the relay you use is rated to handle the voltage. most handle 30vdc or more so you should be ok.
if its jammed force it - if it breaks in the process it needed to be fixed anyway
posted_image
