pulsed to timed
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30414
Printed Date: April 19, 2026 at 10:27 PM
Topic: pulsed to timed
Posted By: robbie2883
Subject: pulsed to timed
Date Posted: April 15, 2004 at 10:53 AM
i have been racking my brain trying to figure out how to take a 1 second pulse and turn it into a timed output for a bosch relay.  i know they make timed relays, but all the ones I find are like 50 and 75 bucks. I don't feel like spending that much. i'd like to just make it using some caps and resistors if possble. Thanks for any help.
if its jammed force it - if it breaks in the process it needed to be fixed anyway
posted_image
Posted By: xetmes
Date Posted: April 15, 2004 at 11:07 AM
what do you want it to do?
After a pulse stay on fo a certain period of time?
Date Posted: April 15, 2004 at 3:15 PM
yeah...about 10 seconds or so
posted_image
Posted By: markcars
Date Posted: April 15, 2004 at 4:15 PM
Use a 555 timer. One of the most versatile timers I have ever used. Options are almost limitless.
Date Posted: April 15, 2004 at 10:35 PM
i've heard about these. they have them at radio shack right? can you give me any info on how to wire it up? it's an intigrated circuit right?
posted_image
Posted By: xetmes
Date Posted: April 16, 2004 at 6:25 AM
its a small IC that can be used in a monostable set-up. here is a circuit and timing calculator. You may want to add a transistor to the output to drive a realy.... They can operate at 12V as well, no need to drop the voltage down.
Date Posted: April 16, 2004 at 6:51 AM
thanks man....that will work. one thing though.....will the output be + or -?
posted_image
