Relay Installation?
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30628
Printed Date: March 25, 2026 at 2:20 AM
Topic: Relay Installation?
Posted By: Scottiee25
Subject: Relay Installation?
Date Posted: April 18, 2004 at 9:25 PM
I have a set of fog lights hooked up right now as the blinkers. My factory blinkers could not be used because of the knight rider nose on my car. They work great as blinkers with out any problems. Now I am wanting them as the front parking lights and blinkers. I know that the factory blinkers have a dual fillament in them to make them work as blinkers but I figured if I could put in a relay so that when I turn on my parking lights, the relay will turn on the fog lights but when I turn on the blinkers, the relay with switch on and off making the fog light blink. This is what I am trying to achieve. If anyone knows how to wire up the relay to do this, please let me know. I dont have any relays at the moment to test to see how I could do it.
Posted By: robbie2883
Date Posted: April 18, 2004 at 10:40 PM
try this
30   - output to parking lights
87   - 12vdc
87a - input from parking light switch
85   - negative input from turn signal
86   - 12vdc
if turn signal output is 12vdc...then you will have to put a ground on 86 and not 12vdc
you will need to use two relays...one for each side
if its jammed force it - if it breaks in the process it needed to be fixed anyway
posted_image
Date Posted: April 18, 2004 at 11:50 PM
Thanks. I will have to stop by the stereo shop and pic up a few relays to try this out. Thanks for the help.
Date Posted: April 21, 2004 at 2:24 PM
brain fart.....change one thing on that relay set up....leave the 12vdc off of pin 87 and just leave it blank
posted_image
