What relay?
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31560
Printed Date: April 21, 2026 at 4:53 AM
Topic: What relay?
Posted By: Powers
Subject: What relay?
Date Posted: May 03, 2004 at 11:00 PM
Hi, I'm wondering if there is such a relay that can 'open a switch' for a 12V lead to my power invertor in my trunk when my accessory line is powered? and close the switch when the voltage stops. these 5 pin relays should be able to do it no? if so, how?
Posted By: boomer_106
Date Posted: May 04, 2004 at 12:27 AM
Yes these 5 pin should work fine. Did you look at the relay page here? The links to the left? If you study it you will see what you need to do. Keep in mind that in electrical terms when a switch or circuit is open there is no juice flowing.  Im assuming you want your inverter powered up when your acc. is powered correct? Here is the link
https://www.the12volt.com/relays/relays.asp
Posted By: djfearny2
Date Posted: May 04, 2004 at 1:10 AM
here quick info
amp wire from radio or red acc wire to pin 86 of relay
take the switch out of the inverter and run two wires to this relay where ever it will be
connect one wire from inverter to pin 30
the other to pin 87
and connect pin 85 to ground serface.
87a not used your dont.
Jon
Installer/Help Technician
---coral springs florida---
