Ground interrupt
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32367
Printed Date: April 22, 2026 at 8:37 AM
Topic: Ground interrupt
Posted By: hillbilly71
Subject: Ground interrupt
Date Posted: May 18, 2004 at 10:28 PM
I am looking to momentarily  interrupt a ground wire by using a relay with a ground input. It doesn't have to have a ground input to the relay but it would make it easier.
Posted By: bxscig
Date Posted: May 19, 2004 at 1:21 PM
Use a relay and connect the ground u want to disconnect to that relay's NC pin and then trigger the relay pin 85 with the ground while 86 is +12Vs.  pin 30 would be the ground u want it connected to.  that will break it as long as the relay is activated.
