Power locks
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32992
Printed Date: April 12, 2026 at 3:36 AM
Topic: Power locks
Posted By: y2kRocket
Subject: Power locks
Date Posted: May 30, 2004 at 5:41 PM
I installed after market power door locks in my sunfire. I used 2 relays. The problem is that when I try to add a second switch to lock / unlock, the relays appears not to be strong enough to drive both both motors, it work fine with one switch, but I need 2 switches. Any ideas?
Posted By: boomer_106
Date Posted: May 30, 2004 at 10:11 PM
more relays?
Posted By: auex
Date Posted: May 31, 2004 at 1:15 AM
How are you tying in the extra switch?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: auex
Date Posted: May 31, 2004 at 10:33 AM
Ok, your problem is that you are making this too complicated. All you need is this diagram. Then wire your switches to pass a negative trigger. Wire your switches to the (-) Lock input's (labeled as alarm(-)lock/unlock output).   Then this will work. Using multiple setups is what is causing you to blow fuses.
