relays needed to prevent burnt PW motors
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35772
Printed Date: April 03, 2026 at 10:28 AM
Topic: relays needed to prevent burnt PW motors
Posted By: TECh9
Subject: relays needed to prevent burnt PW motors
Date Posted: July 18, 2004 at 4:37 AM
I just got some power window kits installed in my car....but I just hooked the 2 power window motor lines to the switches & to the power source...works great... my only concern is will i need a relay to prevent the motors from burning out?....fuses?... anything?... I am fairly new to the electrical world with just basic radio install knowledge so bare with me if you can explain what's needed or not to me.. thanks....
Posted By: sparkie
Date Posted: July 18, 2004 at 5:47 PM
Use a fuse or circuit breaker within a few inches of the point that you attached the main power wire to. For two windows you want a rating of about 25 amps for the fuse or breaker.
------------- sparky
Posted By: auex
Date Posted: July 18, 2004 at 8:34 PM
^^^ Self resetting circuit breaker may work. Motors may have a thermal switch built in as well.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
