Why do I need a Relay, or do I?
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40191
Printed Date: May 15, 2026 at 12:14 PM
Topic: Why do I need a Relay, or do I?
Posted By: stevertr
Subject: Why do I need a Relay, or do I?
Date Posted: October 03, 2004 at 6:52 AM
I want to add to axillary fog light" type lights to a 2004 Yukon Denali, which will sit on top of the new Brush Guard.
My question is why or if I need to add a relay... I want these light son anytime the headlights (high or low beam) are illuminated.
My plan was to just have the wire coming off the new lights run to the back of the headlights and then I was going to just splice right into the Parking Light hot and cold lead.  So whevever the parking lights are on the new lights would be on too.
It seems like Electrical 101, but to be honest I don't trust my level of knowledge compared to the experts here.
Your advice would be graciously appreciated.
Steve
Steve
Posted By: sparkie
Date Posted: October 03, 2004 at 3:43 PM
You require a relay to do what you want. Adding more lamps onto an existing circuit will draw more current than the existing circuitry and fuses are rated for. You will cause damage to the existing wiring and components, not to mention blowing a fuse. Use a relay triggered by the parking light wire to supply your new lamps with power. Don't forget to fuse the relay's power feed..
sparky
Posted By: stevertr
Date Posted: October 04, 2004 at 12:14 PM
Do you have any instructions for a complete novice on how to do this?  I'm pretty comfortable with the task...and have worked on all my vehicles, I just haven't done this issue.
For example do I pull power right at the Battery?  When I think of a relay, I think of plugging it into a fuse block where all the wiring is coming up from below in a pre-wired harness.  I've never added a new relay.  Are there terminals on it or something?? Does it come with a new block to plug it into??
I'm assuming from posts I've read that what you want me to do is to pull power from the battery terminal to this new relay that I've got to buy somewhere.   This relay, from what i've read, will have a 12V lead, then a ground, then a hot wire going to the new lamps, and then this "trigger wire" that I must have to splice in in-line on the existing parking lights.  Is that correct??
When I splice into the parking lights, am I splicing into the Hot Lead or the Ground?
Is there just one wire coming off the lights that goes to the relay or is there also a ground? If there's a ground do I ground that to the relay or just to chassis somewhere?
Thanks for your help.
You guys have a great resource.
Steve
Steve
Posted By: kronik66
Date Posted: October 08, 2004 at 10:59 PM
this should do it.
posted_image
";P
Posted By: kronik66
Date Posted: October 08, 2004 at 11:02 PM
posted_image
";P
Posted By: the1alchemist
Date Posted: October 12, 2004 at 8:59 AM
The way i put it(and PLEASE realize i am NOT trying to be rude!!!)
if you have to ask,to prevent the risk of burning down your vehicle(which i have seen 2 people do in our parking lot over the last 17 years of doing this!!)
please have a professional do it..
'Stereo' Mike
The Audio CARtist,LLC
9600 Balt. Ave.
College Park,MD 20740
301-474-6260
