Resetting a switch
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4138
Printed Date: May 11, 2026 at 1:18 PM
Topic: Resetting a switch
Posted By: mvanhaerents
Subject: Resetting a switch
Date Posted: October 02, 2002 at 6:05 PM
I'm looking to install a switch in a vehicle that will give a constant ground when switched on...but will switch off once positive power (+) is applied.  Is there some type of relay arrangement using a momentary switch to accomplish this...or an actual switch that will turn itself off when power is applied to another set of contacts on it?  I've looked at creating a latching relay that when power is applied that will disconnect the ground, but am not wild about the idea of the relay staying on possibly for long periods of time until the switch is reactivated.
Mike
Posted By: go2pac
Date Posted: October 02, 2002 at 9:14 PM
positive power applied to what?
Karl
Pacific Accessory Corporation
Mobile Audio Interfacing Equipment
Connecting You to Your Music Since 1976
Posted By: djfearny2
Date Posted: October 02, 2002 at 10:22 PM
what are you trying to do if you have an alarm than you can use the negative out of it from starter kill and what happens every time you disarm alarm and start car the negative will be removed . tell me please what you trying to do.
Jon
Installer/Help Technician
---coral springs florida---
Date Posted: October 03, 2002 at 11:23 AM
Basically, I'm using this on my own vehicle for a remote starter.  Its a jeep wrangler with a manual transmission.  What I want to accomplish is when I shut the car off and take it out of gear, I activate a switch that disconnects the chassis ground to the remote starter, basically arming the remote starter.  But once the vehicle is started with a key, I wanted the switch to deactivate or turn itself off until it is re-armed.  The chassis ground will hook up in parallel to the hood pin input on the remote starter...if a chassis ground is not present it will start.
