Thermostatic control and fan using relays
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45663
Printed Date: May 07, 2026 at 7:52 AM
Topic: Thermostatic control and fan using relays
Posted By: illicon2003
Subject: Thermostatic control and fan using relays
Date Posted: December 21, 2004 at 12:24 AM
Ok how's it going I've done research but can't seem to get to the bottom. I need help designing a wire diagram to control 1 or 2 fans, using standard 5 spade SPST relays, or a couple of these honda relays.  See diagram below. I'll be using a 2 wire thermoswitch. I appreciate the help. I know a 30amp fuse must be used
posted_image
Posted By: hotwaterwizard
Date Posted: December 30, 2004 at 12:54 AM
How about this one I drew for you.posted_image
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
Date Posted: January 12, 2005 at 6:57 PM
Hey man thanks alot ! I really appreciate the time. One question though, is that a normally open or closed thermoswitch? Thanks!
Date Posted: January 12, 2005 at 8:00 PM
Depends on the Application. I use it to control a Fuel solenoid.
That application is Norm Closed.
For Cooling you need Normally Open so the fan turns on when it reaches the High Limit you set.
Stockton California
Date Posted: January 12, 2005 at 8:38 PM
posted_image
How does that look, w/ the exception of the artwork?
Date Posted: January 13, 2005 at 8:47 AM
That will do it!
Stockton California
